Cleaning electrical contacts
rjkoop
Post by rjkoop »
After doing the restore of my interior, including replacing fuels lines, I'm having trouble starting my '81. I'll have to check a number of things (eg. fuel supply, spark, etc...) but I'm thinking now might be a good time to ensure all connections are good. Is there a good procedure/spray to clean and treat connectors to ensure good connections? Some people mention di-electric grease.
4uall
Re: Cleaning electrical contacts
Post by 4uall »
rjkoop
Post by rjkoop »
Thanks Jay. I'll take a look later.
Also is there a guide on what the resistance measurements should be for things like spark plug wires, etc...? I measured my spark plug wires and they were 1.5 (not sure of the OHM scale yet - have to check the setting on the meter) for the spark plug wires and 4.5 for the ignition coil wire. Is this normal?
4uall
Post by 4uall »
majicwrench
Post by majicwrench »
Plug wire should be roughly 1000ohm per foot if you have some sort of resistor wires. For the most part a bad wire will show open circuit, so knowing the exact resistance really isn't that important.
There is a product, Stabilant 22A, or something like that. Carquest carries it, so do a few others. It is expensive, it is a contact enhancer, I believe it was developed for the military.
I would recommend you find out why your car doesn't start before you just start dinking with connections.
Keith
