Great drive to Carlisle for the show today, except on final approach what started as a little rattle like a loose bracket on the exhaust became a major racket whenever the engine was under load - very metallic like a shot catalytic converter but I don't have on my '71 of course. As far as I can tell it's coming from the vicinity of the little center muffler. All brackets and connections between the down pipe seem tight. Can these center mufflers fail, and would/could the internals rattle like that?
In addition, getting audible unmuffled engine noise up by the exhaust manifold, diagnosed by a Fiat buddy as a probable blown exhaust gasket. Could these be at all related?
Other than the racket, the car ran strong and enjoyed the day!
Can a center muffler go bad?
Re: Can a center muffler go bad?
of course the center muffler can go bad, probably has a baffle that has rusted loose and is rattling
- srwilson
- Your car is a: 1979 124 Fiat Spider 2000
Yep, got the same issue. Ping, ding, ding, rattle, ping, ping.
Mines seems worse when idling, but it might be I just can't hear it when I've got my foot in it.
-Steve
1979 Black Fiat Spider
2006 Black Chevy Silverado Crew Cab
So mine finally started rattling a little at idle. Tried to visually (audially?) identify the source while poking under the car and all I know is when I push the front muffler/resonator up toward the floor board, the rattle increases. When I let it back down, it goes away. I cannot say with any certainty it is the front resonator. Before I start swapping out exhaust parts wanted to double check with the experts on any additional thoughts?
- azruss
If you have loose baffles in one, give it a rap with your fist or a rubber hammer. Should be able to identify the source that way.
You don't need the resonater, do you?
You can run straight back with a muffler, or can you just use a resonater then pipe it back?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
I bought a center pipe with center resonator only (no forward) already, as I sometimes foolishly do (buying replacement parts when I have not yet diagnosed the problem). I may try to install tomorrow and see if that helps.
