Brake bleeding question
Could (should) you bleed the brakes with the car running?
- 81SPIDERMATT
Re: Brake bleeding question
could you.... yes .... should you ... no.. not needed
I guess I was wondering if the booster/vaccum would help force the air out of the system. im getting very little out of the rears. I am jacked up properly I think (jack stands on the axle).
- Your car is a: 1982 Spider
Depending on what you did(fixed or replaced) there may not be all that much air in the rear. does the pedal feel rather hard or mushy when all bleeder valves are closed. If hard, you should be good. If mushy, there is still air somewhere.
Steve
1982 Red Spider 2000
1919 Old Town Sailing Canoe
Feels ok I guess. Overall seems like I need to "anticipate' stopping a bit more than before but the squeaky front caliper sound is gone.
