cleaning front discs
My car has sat for awhile. The discs are all rusted. What is the best way to clean them off?
Re: cleaning front discs
Are you going to take the rotors off? regardless ,going to tell a story again... when I run wet wood through my planer and the beds get a touch of rust on them (still use furneture polish on the beds) I use an orbital sander with a brown scouring pad instead of sand paper. That with some spray brake cleaner will have them shiny again. If you buy them new I think they are around the $20.00 each.
Chris
Chris
- SLOSpider
Drive it, it will come off.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
- divace73
- Your car is a: 1980 Fiat 124 Spider Silver
I was going to say the same thing...SLOSpider wrote:Drive it, it will come off.
Cheers David
see my >>You tube channel<<
A couple panic stops should do the trick!
Trey
Yep, if you want them clean quick spray a little brake cleaner on them and then drive the car. They will shine like new.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
That is what I usually do, but the rust seems heavy. Thought about scotch brite pads to dress them a little. I am replacing the calipers with NOS ones.
- 124JOE
new rotors are not too pricey
Get them turned
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124JOE
$12 to turn $17 for new
Ok then124JOE wrote:$12 to turn $17 for new
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
