The Infamous Driver Side Rear Bumper Shock Removal
- Your car is a: 1985 Spider
I have everything off the car for paint except the drivers side rear bumper shock. I wouldn't worry about it but I am finally putting on the rear bumperettes. It is my understanding that the gas tank can be raised slightly and slid over to allow the bolt to come free. Any other secrets I need to know? Can I do it without taking the filler hose off?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
- danaspider
- Your car is a: 1979 Spider 2000 79 vw bus
Re: The Infamous Driver Side Rear Bumper Shock Removal
I did this recently, I removed the 4 nuts holding the gas tank and used a car jack under the tank. I then raised the tank the few inches needed to get it to slide to the passenger side to get the bolt removed. I did remove the shield from the main filler tube so I could make moving the tank easier.
Just take it slow and move easy.
Luck Dana
79 Spider 2000
carb
79 Spider 2000
carb
- 124JOE
just pull the tank so you can reseal it to the car when done
yes remove the filler hose and fuel lines
i scraped and repainted the tank while out
also repainted the trunk floor
and used a window seal for the tank to body seal
it looks good
it looks good
