In my manual it says "pry off the plastic ball and socket door lock link". I have the brackets off, where are these? I don't want to force something with out really knowing how it is to come apart.
Door Handle Removal
- Your car is a: 1985 Spider
Door Handle Removal
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
- aj81spider
Re: Door Handle Removal
The little plastic rectangle at the top of the rod has a hole on the side. There is a ball that snaps into that hole. Gently pry it away from the handle and it will either pop out or shatter completely (the plastic is 30 years old).
Thankfully mine popped out nicely.
A.J.
2006 Corvette
2006 Corvette
aj81spider wrote:The little plastic rectangle at the top of the rod has a hole on the side. There is a ball that snaps into that hole. Gently pry it away from the handle and it will either pop out or shatter completely (the plastic is 30 years old).
Got them both out. Now I just have to worry about how to put them back.
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
- azruss
install the one on the door latch before installing. gently squeeze the plastic on the ball with pliers. after install, you can get the pliers in the door to do the top.
