wandering from home
Posted: Mon May 06, 2013 1:29 am
This morning i took the half finish car out to cruise the neighborhood. Had it out long enough to heat up the car and a half dozen young boys oggle at the car. maybe 20 plus blocks in total. Here is the results. Car hasnt run in a month and started immediately. the low speed thunk is gone now that i have the wheels mounted right. car pulled a little, no surprise as cc and a are way off. brakes are firm but need to be broken in. The car smell like a Fiat. This is a good thing. Generator light was on the whole time. measured 13.2 volts at the battery. The temp gage settled in at the hot side and then ran up close to the red. Fan didn't come on until the end of the trip. bottom of radiator was hot, but not too hot to touch. Wondering if the alt light meant the gage wasnt reading right. oil level up and clear with no water. no sign of oil in the coolant. brake fluid level holding steady. No signs of leak except a little trace oil on the bottom of the pan. looks like it is coming from the plug threads. Shut the car off and restarted 10 minutes later and it started right up. drove thru the dips in the road without caution and did not scrape the spoiler.
