Blinker kit from mark
Where do most people mount this lights, I'm bumper less
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 81SPIDERMATT
Re: Blinker kit from mark
i used the oval holes.... they need to be "wallered out" a bit
Ok great, so they need to be a bit bigger81SPIDERMATT wrote:i used the oval holes.... they need to be "wallered out" a bit
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 81SPIDERMATT
you just have to round them out a bit...the holes as is are wide enough just not tall enough if you know what i mean.. do a little at a time and then check fitment .... i would wait until you have the kit in hand..... dont just round them out
Thanks, i have them. I just have not looked at them yet. I seems to loose stuff in my garage.81SPIDERMATT wrote:you just have to round them out a bit...the holes as is are wide enough just not tall enough if you know what i mean.. do a little at a time and then check fitment .... i would wait until you have the kit in hand..... dont just round them out
What did you use to cut it out
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 81SPIDERMATT
i used some type of grinding thing that fit in my drill... looked like a small barrel .... the guy at ace said it would work... not a whole lot needs to be removed.... did not trust my abilities with my big grinder tryiing to finesse a cut in that small space.... worried that i would cut too much or catch and run a big scratch.... and the sawzall seem to be overkill
i seen that not much needs to be removed
how did u fasten that light? what did you use on the back side?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
the light has a cup that mounts from the back side to secure the light
Ok I was thinking that's how it would go, but was not positive, thanksSo Cal Mark wrote:the light has a cup that mounts from the back side to secure the light
And I got to buy my own nuts? Lol
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- SLOSpider
Don't JACK UP that light install
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
with a Dremel or similar grinder, remove a slight amount of metal from the top and bottom of each bumper shock hole. The rubber grommet will fill the gaps around the edges of the lights.
- toplessexpat
While there's nothing wrong with the blinker light kit ...
... I elected to fit some custom truck headlamps with integrated LED blinkers in the the bottom 10mm or so. There's also a row of LEDs for the park lights.
Ping me if you'd like pictures - on the Texas Hill Country run a couple of weeks back, people saw mine and weren't overly critical
Andy
Andy
- SLOSpider
Post up some pics topless
1975 124 Spider
