Floor rail
fiat218
Floor rail
Post by fiat218 »
Has any one thru there years I of buying a spider ever run across where some dum azz smashed down th floor rails like this
I'm wondering if I Need to remove the center peice, I got my new rails here but I have not open the box yet, as I'm typing it ws dropped off, if I cut way where they fit,I should be ok?right
Ok I open the box,here is the rails, notice the higher one,that got the passenger side, I got 2 of them
Lower are the drivers side, why are they different height ?
Ok the question was, as you look at the rails you see how the inner is shaped up ward, I do understand why it is like that
But I don't have that metal there any more ,it smashed all down,
Would I need some support under that part? I'm thinking I don't
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
azruss
Re: Floor rail
Post by azruss »
that cross support is there to take the weight of the seats and passengers. I would try to repace it with some type of channel. The tall ones are for the bump in the floor boards on cat models.
RRoller123
Re: Floor rail
Post by RRoller123 »
Prior PO probably had non-stock seats that needed that little extra space provided by beating down the rails?
fiat218
Re: Floor rail
Post by fiat218 »
azruss wrote:that cross support is there to take the weight of the seats and passengers. I would try to repace it with some type of channel. The tall ones are for the bump in the floor boards on cat models.
ok thanks ,
wont the tall ones make the passenger seat higher lol
i have the driver side metal all ripped out
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: Floor rail
Post by fiat218 »
I'm almost ready to get my rails welded in, I got to order the cross member bars first,they go under the rails
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: Floor rail
Post by fiat218 »
RRoller123 wrote:Prior PO probably had non-stock seats that needed that little extra space provided by beating down the rails?
He did,I think ther Honda seats , I really don't know,I'm throwing them
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: Floor rail
Post by fiat218 »
As I was installing the starter,I looked up and seen light thru the driver side floor pan. I wasn't to thrilled,then I thought hell that won't be to bad
Later I thought,I might as well fix it because I got to get the rails welded too, so I ordered that pan, passenger side is great
More expense :o
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
SLOSpider
Re: Floor rail
Post by SLOSpider »
Where did you get your rails from?
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
fiat218
Re: Floor rail
Post by fiat218 »
Rails from vicks
The center piece that goes across under the rails,got them from wolf steel and the driver side floor pan
Cheaper to get them from wolf steel, I would have saved 180.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: Floor rail
Post by fiat218 »
Vicks is like 149 for the rails and 189 for the crossmember piece
Wolfs steel is a 1/3 of that price
The guy name is robin wilkinson, sounds like a very good person
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
4uall
Re: Floor rail
Post by 4uall »
They are nicer.....................trust me on this one :wink:
SLOSpider
Re: Floor rail
Post by SLOSpider »
Ok Ill see if he responds to my email last night before I make any long distance calls :) Thanks
1975 124 Spider
4uall
Re: Floor rail
Post by 4uall »
Think of them as you would Auto Ricambi. I have seen numerous references to them in local forums etc (all good experiences). :wink:
