cruise control
- 81SPIDERMATT
cruise control
81 spider ... done some searching and seem to be a lot about dual throttle cables on earlier models "poor mans cruise control" ...not wanting something like that.... googled aftermarket cruise controls and jargon reads like a medical book to me.... hoping someone can recommend a specific unit with good directions that would work on my car..... thanks for help and willingness to share.... Matt
- SLOSpider
Re: cruise control
Only installed one aftermarket back in the 80's that you glued magnets to the driveshaft and bolted up a sensor to the body to ready the rotations. Worked ok. If you need cruise control it just means your driving on the wrong roads
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
- 81SPIDERMATT
Re: cruise control
agreed .. but on occasion got some highway miles to get to those roadsSLOSpider wrote:Only installed one aftermarket back in the 80's that you glued magnets to the driveshaft and bolted up a sensor to the body to ready the rotations. Worked ok. If you need cruise control it just means your driving on the wrong roads
- toplessexpat
Re: cruise control
I've got it on my '76. It's lethal... do not even think of using it as Cruise Control! The real thing means you touch the accelerator or the brake and it turns off... this doesn't!
As a handy throttle setting point for warming the engine though - it's excellent...
Andy
Andy
Re: cruise control
There is nothing Balto Bernie cannot make. Don't ask about the ejector seat and rocket pods. The McGuyver of the DCFIAT club.
- 81SPIDERMATT
Re: cruise control
several different ones ranging in price from 90 to 300 is it.... Audiovox CCS100 Universal Cruise Control .... looks like the same switch in the ashtray
Re: cruise control
The orange wire goes to the .... no! the pink wire goes to ...
You going to Katie's tomorrow for Carl's run?
Re: cruise control
I've put in dozens of em over the years. Most of the modern ones do not use magnets, but use the coil(-) rpm signal. They are fairly simple to install, just follow directions.
Keith
Keith
Re: cruise control
Funny. Car is still in the paint shop. Carlisle will hopefully be its coming out party....was also the first event for me after I bought the car last spring.
On cruise control, agree the primitive lock-down-the-gas mechanism in my '71 has to be used judiciously. It was a blessing when I took the car on a long interstate drive with no traffic - would never use like a modern cruise control.
Re: cruise control
In north Dakota', all we got is flat straight roads for miles,
hell 200 miles of straight shots from one end of the state to the other
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: cruise control
baltobernie, can you post a few photos showing how you installed the cruise control servo, etc., in the engine compartment?
Re: cruise control
I get the long flat road and making long highway drives more bearable as a reason cruse control is a desirable option. For me, I like the idea of one less modern convienance item on a classic roadster. One of the benefits of not having cruise control is the need for the driver to control and vary the RPM's. IMHO the engine performs better when you vary the RPMs on a long drive. No airbags, anti lock brakes, tire pressure sensors, micro chip key, reverse bumper sensors, self parking programming, cruse control, electric windows....
Driving the Spider brings me back to old time driving where the driver is in complete control. It's one of the things i love about these cars.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
- toplessexpat
Re: cruise control
Absolutely! Although - I do like my TPMSNo airbags, anti lock brakes, tire pressure sensors, micro chip key, reverse bumper sensors, self parking programming, cruse control, electric windows....
- Patron 2024
Re: cruise control
I have a few photos. I installed the Audio Vox speed control actuator in place of the windshield washer bottle. If I were to do it again I would try and install it behind the headlight bucked behind the fender liner and have he wires and control cable pass through the fender well. I made a custom center console and mounter the controller in place of the ash tray.
Hope this helps. The AudioVox scs100 uses both magnets on the drive shaft and the coil pick up. I installed the magnets on the short drive shaft section between the transmission and the drive shaft bearing. Once I figured out the dip switch settings I am amazed at the cruise controls performance. I installed it about 6 years ago and it has over 20,000 trouble free miles on it.
