Transmission 5th Gear
davery
Your car is a: 1985 Spider
Post by davery »
I have seen a couple of new trans that have a smaller 5th gear ratio, for lower RPM's on the highway.
I think the factory 5th is 87:1. I have seen new trans with 82:1 and 78:1
My question is can these be purchased and added to my existing trans?
I would really like to drive my spider on the highway for extended periods.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
SLOSpider
Re: Transmission 5th Gear
Post by SLOSpider »
You can drive that thing across country no problem as is. Don't know about the other gears ...
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
vandor
Post by vandor »
Not yet. Maybe in the future. I've been trying to convince my machinist friend to make some for a long time...
80124FI
Post by 80124FI »
I have been wondering the same thing. Or if there is an option to change the pinion and ring to drop RPM ... 70mph seems to have this engine screaming
the twin cam likes to scream
narfire
Post by narfire »
So Cal Mark wrote:the twin cam likes to scream
I don't know if 4500 rpm is screaming, but I will drive 400kms or so with the engine in that territory and still get around 30 miles per imperial gallon in a slightly modded 2L FI.
Car runs great and temp is not an issue. (touch-wood)
131
Post by 131 »
narfire wrote:I don't know if 4500 rpm is screaming
Approaching 6k/rpm is starting to scream, anything less is normal driving, (despite what my wife thinks).
Mick.
Tobi
Post by Tobi »
To let your motor scream is like blowing a stuffed nose!
G+B Motorentechnik in Germany offers a longer 5th but that's got to be expansive and you would have to ship the transmission there.
Talking about Germany....going on an Autobahn and floor it and you will have it scratching the redline for as long as you want.
4500 rpm is nothing, most people in the U.S. are just not used to it.
