E-brake handle and heat controls
rjkoop
Post by rjkoop »
As part of my 'rolling restore' I removed the heater controls and the e-brake handle.
They are both rusted so I'd like to refinish. I'm thinking...
- prep and POR-15 base
- wire wheel handle and controls
- prime with primer
- re-chrome
Should I paint black (maybe the controls) or chrome (e-brake)? If chrome can I re-chrome the pieces myself? There is a spray re-chrome but it got some bad reviews (at least the Duplicolor). Or should I send them out to be re-done?
Also I noticed that the e-brake handle doesn't have a button/whatever) to release it. Is mine missing this piece? Anyone have a picture of a functioning one?
SLOSpider
Re: E-brake handle and heat controls
Post by SLOSpider »
The lever bezel may clean up. Soap and water and a good scrub brush. Some 000 steel wool. If the brake lever is missing the release button then you will have to get a new one or another lever. Unless you are chroming other items Id just paint it.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
azruss
Post by azruss »
I would ask in the "parts wanted" section to see if any of the group has one. Wouldnt take much to get one in better condition than yours. would be cheaper than rechroming.
rjkoop
Post by rjkoop »
SLOSpider wrote:The lever bezel may clean up. Soap and water and a good scrub brush. Some 000 steel wool. If the brake lever is missing the release button then you will have to get a new one or another lever. Unless you are chroming other items Id just paint it.
Guys,
Thanks for the quick advice. Steel wool worked great!
Before
After
And I realized that the button was just stuck and not broken.
Onto the next job!
SLOSpider
Post by SLOSpider »
Nice! Now clear coat it or keep a good coat of wax on it.
1975 124 Spider
