What is this part?
What is this part?
Above rear axle. Is it OK to be loose and rattly or should it be tight? I am hearing a loud click on accel/decel. Almost like something separating then snapping back. Could it have something to do with this loose part?
- SLOSpider
Re: What is this part?
That is your Brake Compensator Linkage Rod. It has plastic bushings that go in those two holes that are commonly missing. Should replace and see if that is your noise.
Any Fiat vendor should stock them 4 total as they are split in half.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
- kmac33
- Your car is a: 1974 Spider
George,
The brake compensator is designed to keep the rear brakes from locking up under panic/hard braking. As the front end dives and the rear rises, it "activates" and releases the rear brake pressure. I would not be surprised if yours is no longer functioning correctly. When I first started my resto, mine was "frozen" = no rear brakes.
I ended up just by-passing and removing it. Most of the vendors sell the by pass hose - pretty common mod.
Kevin McMullen
1980 Fiat Spider
2013 Subaru WRX
1980 Fiat Spider
2013 Subaru WRX
Thanks guys, any idea if this part, with no bushings, would make an audible clicking or rattling sound?
Probably Here is a good photo http://www.autoricambi.us/product/BR0-4 ... d-Bushing/
- SLOSpider
Be a good time to change that OE rear brake hose too
1975 124 Spider
