Does anyone have any suggestions on how to handle a very rusty bumper stud on my 1973? Here are a couple of pictures:
As you can see, the rubber seems to have been a great moisture trap and the stud has rusted away to almost nothing. Does anyone know how this stud is attached? It seems to be welded in and there does not seem to be any access behind it. A couple of possibilities are to weld a threaded sleeve around the base and just put a piece of all-thread into that or maybe cut it off, drill and tap for a new stud (but I don't know if there is enough depth to the metal in this area to support enough threads).
Suggestions are welcome!
Thanks,
Brian
Bumper stud question
- hayesbd
- Your car is a: 1973 Spider
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
- 124JOE
Re: Bumper stud question
it looks like a post that screws over a stud
pb blaster for a few days then heat and turn it off with a pipe wrench
if it snaps then drill it out and put in a bolt from the inside
hope this helps???
joe
hope this helps???
joe
It looks so rusty that it should snap right off!
If you can, drop that valence just below it. Looks like they are screwed on. Once that has been removed, you'll have more room and from the pic, might even be able to get behind it. If you can't get behind it, then easier to cut off, grind flat and then weld another stud on.
