Flushing Cooling System
- Your car is a: 1983 mira
What is the best way to flush and clean the cooling system of a 124 Spider
Re: Flushing Cooling System
Google found me this http://archive.mirafiori.com/show.php?fid=2&msg=3084
You can add a cooling system flush, then do a heater hose T flush. Prestone sells a kit for doing the flush.
Don't forget to undo the block drain plug on the exhaust side of the block, in the middle.
any chance of a photo of what that looks like? (so I don't pull the incorrect one)vandor wrote:Don't forget to undo the block drain plug on the exhaust side of the block, in the middle.
I don't have a picture but it is typically a small brass plug just below the freeze flugs. Maybe 6 or 8 MM. You can't mis it.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
