http://blogs.capitaljeep.com/wp-content ... 24x882.jpg
Wheel Alignment
Description: Inspect the front and rear suspension components for any signs of wear or damage. Using specialized wheel alignment equipment, adjust the suspension and wheels to the vehicle manufacture's specifications.
Significance: Vehicle suspensions can wear with age and repeated heavy use. Rough road surfaces and an occasional pothole can change the vehicle's wheel alignment. A wheel alignment can improve our steering control and overall vehicle handling. It can also help prevent abnormal tire wear by bringing the vehicle suspension components back to the vehicle manufacturer's specifications. This important step will keep your vehicle driving the way it was designed to. An alignment is necessary any time a worn suspension part is replaced.
Advantage: Even slightly worn suspension components can affect the vehicle's wheel alignment. This can lead to premature wear of tires and reduce overall vehicle comfort and safety. A vehicle with worn out suspension parts can be unsafe to drive. Maintaining your vehicle suspension and performing regular wheel alignments and tire rotations can keep your vehicle safe and reliable.
