Has anyone used this product?
http://www.lobucrod.com/index.html
floor insulation
- Patron 2021
Re: floor insulation
AWESOME STUFF
http://forum.fiatspider.com/f08/viewtop ... it=ez+cool
http://forum.fiatspider.com/f08/viewtop ... ol#p140435
- Patron 2021
Thanks for the reply Jay,much appreciated!
How much did it take to do the floors?
Thanks again!
Bob
Thanks again!
Bob
- giuliot60
- Your car is a: 81 Fiat Turbo removed Spider
Look like this is the stuff to use. And you don't have to figure out which side goes up, since it has the reflective aluminum on both sides.
Giulio/Charlotte
- Your car is a: 1980 Fiat Spider 2000
It took me only one roll. FYI,
I installed mine left the heat shields off for a bit and the floor never got hot directly over the cat. I would highly recommend this product.
spiderbob79 wrote:Thanks for the reply Jay,much appreciated!
Thanks again!
Bob
Just one roll is all I needed. Had some left over for the trunk area
- opus10583
- Your car is a: 1978 CS1
Hi,
Me too: One roll. I did it over sound mat.
No heat whatsoever from the outside in.
Ciao,
Mark
Ciao,
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
- giuliot60
Did you guys use the tape that they sell or something else. And please talk about how you adhered it to the floor (and other surfaces). I know some use spray adhesive, and some just lay it down without any adhesive.
Thanks.
Thanks.
Giulio/Charlotte
for mine I simply cut it to fit, then laid it in, then put my home made carpeting onto then rubber mats et voila
Nothing has moved or bunched up since
The last thing I wanted to do was to re-do all the tar/carpet removal I had just done in future years
- opus10583
Hi,
Spray adhesive for me, in case I didn't like it.
I have a roll of Jute if anyone needs it.
Ciao,
Mark
Ciao,
Mark
