Drain gas tank
rjkoop
Drain gas tank
Post by rjkoop »
I'd like to drain the gas tank to replace the fuel lines. It may stay drained for a few months. Is that ok or will rust occur? If so what can I treat it with? The tank was actually replaced about a year ago so it's in great shape right now.
BEEK
Your car is a: 1975 Spider
Re: Drain gas tank
Post by BEEK »
are you removing the tank from the car?
75 spider
son has 78 spider
rjkoop
Re: Drain gas tank
Post by rjkoop »
BEEK wrote:are you removing the tank from the car?
Nope. Just replacing lines in car. Or is there a shutoff somewhere I can use instead? I'm just worrying about gas draining out fuel pump when I disconnect lines.
124JOE
Re: Drain gas tank
Post by 124JOE »
use a pair of vicegrips on a rubber piece closest to the tank
this will close off the flow
i removed the line up ft at the filter and drained into a big container
at 30 plus yrs old you should go through all rubber and replace it
including the fill tube
the last thing you want is to get it all back together and find an old leaking line
narfire
Re: Drain gas tank
Post by narfire »
124JOE wrote:at 30 plus yrs old you should go through all rubber and replace it including the fill tube
I'll second that. I neglected to change one short piece of original rubber fuel line in the 72 and after charging the system with fuel, sure enough it leaked bad.
Chris
rjkoop
Re: Drain gas tank
Post by rjkoop »
I agree. I know the PO replaced gas tank and some lines. I'll have to visually inspect and figure iut which ones are old.
