Removing welder seat rails
rjkoop
Post by rjkoop »
I need to remove a partially rusted seat rail beneath the passenger seat on the right. I read on a post that these could be spot welded in and I could drill out the welds and remove the rail. On my car it looks like it's part of the pan and I don't see spot welds. Any ideas on how to remove? Maybe I could get a chisel underneath and pry it up. Or cut and then grind down what remains.
ososbob
Your car is a: 1980 Fiat Spider 2000
Re: Removing welder seat rails
Post by ososbob »
I used an air chisel to remove mine, and they were spot welded. Keep in mind I built my own seat rails to replace them.
redcars
Post by redcars »
The rails are spot welded in and if you clean it up enough you will be able to see them. When I removed my bad floor pan I drilled mine out and then made piece to repair what was bad. You can buy seat rails if it is more work than you want or can do. I have a lot of equipment to it is no big deal for me.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
rjkoop
Post by rjkoop »
Air chisel? Sounds like it's time for a new tool! :D At Cdn Tire in Canada the tools sometimes go on sale really cheap (eg. 70% off). No idea why but you can sometimes get a $100+ tool for $29!
eman2112
Re: Removing welder seat rails air hammer
Post by eman2112 »
Harbor freight for 16 bucks. Get a chisel kit with it. Just grind the v-groove chisel flat.
