Cam pullys swirtched
btexpress
Post by btexpress »
I am told it is possible to switch the intake and exhaust cam pullys . Does anyone know how to tell the difference by looking at them ie. stamped with a code. They do not indicate left or right. A local fiat mechanic said there is a subtle way to tell but did not tell me how. There are some numbers and letters stamped on the pully but nothing I can understand.
srwilson
Your car is a: 1979 124 Fiat Spider 2000
Re: Cam pullys swirtched
Post by srwilson »
Take a look at this thread. There may be some pictures that might help.
http://www.fiatspider.com/f08/viewtopic ... 30#p172435
-Steve
1979 Black Fiat Spider
2006 Black Chevy Silverado Crew Cab
SLOSpider
Post by SLOSpider »
Searching always helps :) Quick answer is with the pullies facing you as they would be on the cams the dowel holes in the 12:00 positions you will see that the intake alignment hole will be just left of the 12:00 position and the exhaust will be just to the right. Also may have STAMPED in the metal S for exhaust and A for intake.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
divace73
Post by divace73 »
SLOSpider wrote: Also may have STAMPED in the metal S for exhaust and A for intake.
Just to add the S stands for Scarico which is Exhaust in Italian and the A is Aspirazione which is Air intake
Cheers David
see my >>You tube channel<<
btexpress
Post by btexpress »
Thanks for all who replyed. You have been a lot of help.
