Questions about seat rebuild
rjkoop
Post by rjkoop »
I took apart my seat to rebuild/POR-15 the frames. Everything is done but I think I may have put the seat cushion/base on the opposite seat base frame. This is the piece I'm referring to...
Does it matter? They look the same to me and they fit so I think they're interchangeable. Also does the seat rail adjustment (ie. to slide the seat back and forth) go near the middle console for each seat? I think so but just wanted to be sure.
4uall
Re: Questions about seat rebuild
Post by 4uall »
I have swapped my driver & passenger seats with no issues :)
4uall
Post by 4uall »
was not sure if you were still looking for the bottom seat portion :?
This may help http://www.ebay.com/itm/Fiat-2000-Spide ... ae&vxp=mtr
wikkid
Post by wikkid »
I wonder if those rubber straps across the seat bottom are replaceable, and/or available? I'm pretty sure after so many years, mine would be shot, and need replacement. Anyone?
rjkoop
Post by rjkoop »
Got the seat frames rebuilt fine. They look pretty good and re-enforced with new steel in a few sections.
narfire
Post by narfire »
wikkid wrote:I wonder if those rubber straps across the seat bottom are replaceable, and/or available? I'm pretty sure after so many years, mine would be shot, and need replacement. Anyone?
Would sections of truck inner tube work? Double up if needed.
4uall
Post by 4uall »
I was also thinking about a leather belt or have them fabricated :wink:
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
When I was building a gyrocopter (many years ago). The seat used truck tire inner tubes. They look similar to the Fiat seat bottom.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
