Interchangeable parts
akawes
Post by akawes »
What year spiders will interchange with each other?
akawes
Re: Interchangeable parts
Post by akawes »
also if i was going to put the 2000cc into a 76 what would i need to do that?
divace73
Post by divace73 »
'most' parts are interchangable, mainly mechanical, doors should swap, I'm lead to beleive the dash and windscreen did change, just don't when it happaned, the roof (we call hood) are different over the models, the early bonnets (what you call hood) are slightly different in length, the 2L is possible you may have to the following
smaller engine mounts
2L cross member
Change bonnet/hood for clearance
possibly move the dist to the block
If a FI 2L you will need to change the fuel lines and either put a swirl tank or a 2L FI Petrol tank.
The above are possibilites, I have heard people do it with very little to modify
Anyone out there who had done can comment?
Cheers David
see my >>You tube channel<<
akawes
Post by akawes »
Ok because I was wondering what year doner car I should get for a 76. If I could not get a 76.
if you stay with 78 and earlier, you'll find more parts interchanging than 79 and later
vandor
Post by vandor »
>doors should swap
Nope, changed around 73-74.
For a '76 Spider the best donor car is 1975-76, next best 1973-78. 1974-78 had the 1800 engine.
If you want a 2000 engine you need a 1979 or newer donor.
