What do guys think - how much longer before replacement ?
Brake pads replacement ?
- Special
- Your car is a: 1974 Special TC
My Green Car aka Torrino - http://www.fiatspider.com/f15/viewtopic ... 30&t=30089
Re: Brake pads replacement ?
Sorry for my ignorance, but what on earth is the benifit with that design? Looks like a tree/debris grinding wheel.
Chris
Chris
The pad material has worn away, the metal backing plate has then ground down the disc surface until it is also completely gone, showing only the internal webbing of the vented disc.
We had a vehicle towed into the workshop many years ago, the only reason the owner stopped driving it was because the piston had pushed out of the caliper and jammed in the vented disc webbing. The disc surface and pad backing plate were completely worn away. Besides the effect on braking, the noise would be horrendous, I can't comprehend how a person can continue driving a vehicle to get to this stage of damage.
Mick.
- focodave
131,Besides the effect on braking, the noise would be horrendous, I can't comprehend how a person can continue driving a vehicle to get to this stage of damage.
You obviously haven't met my best friend's wife!
Dave
1970 MGB GT (my other hobby)
Imagine how smooth the braking would be on that set up? Stopping distance? Noise? Feel? How many people do you think walked up top the car and said. "you need to get your brakes fixed".
Did the owner ever fix the car once towed to the shop. I can only imagine what else needed repair leading to a car being grounded. If you can't afford new brakes then you can't afford the big repair bill that will come with a neglected spider.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
during my long journey through this life, I've had two customers drive their car into the shop with brakes in that condition. You can't imagine the commotion when they stepped on the brake pedal
The worse brakes that I have seen the rotor was ground all the way off on a volvo and the two pistons where touching each other. The wheels where pitted with rust from the iron.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
- Special
I've never seen anything like this in my life.
So I could not pass by this without taking the picture.
This car must have a good stereo to cover that noise.
Some people .......
Some people .......
