Are seat backs adjustable?
Would like it if my driver's seat could angle back just a bit more when at it's 'upright' driving position. I just had it reupholstered, and it needed some welding repair inside, but now it looks great but seems a bit too 'upright'. Does anyone know if the setback angle is adjustable? I wonder if i can adjust it, or if got screwed up somehow with the welding repair....thanks for any thoughts on this.
Re: Are seat backs adjustable?
Isn't there a lever on the side?
Trey
- Your car is a: 1979 and 1980 spider
On mine 79 and 80 there is a wheel on the hinge. Turning to one direction will make the back rest to go one way, turning the opposite direction will make to go the other way. So you should have two adjustments on the hinge, on the door side. One is a level and one is round about 3" diam.
- JEEPER
- Your car is a: 1979 SPIDER
MY 79 is the same.lm48 wrote:On mine 79 and 80 there is a wheel on the hinge. Turning to one direction will make the back rest to go one way, turning the opposite direction will make to go the other way. So you should have two adjustments on the hinge, on the door side. One is a level and one is round about 3" diam.
The dial is located on the right seat at the bottom
