katsi wrote:What do you use to plug the reed valves on a 79? I have tried every size oil plug I can find and none of them fit. I'm guessing it's a 16 mm but I can not find anything to fit. Anyone had any luck with this? Getting tiered of standing in line at the return counter.
Do you want to screw something into the reed valve, or remove the reed valve and plug the hole in the head?katsi wrote:The question should have been, what size threads will fill the reed valves.
Ok, It's just that M-14 is the largest size in all 3 auto parts stores in town and it just falls in the hole. I'll keep looking.lanciahf wrote:Again 79 to 80 reed valve threads are either 18mmx1.50 or 16mx1.50. See my answer above
