gear ratio
gear ratio
i have a 1979 carbbed spider and i am buying a 1981 FI spider parts car. i was wondering if the 1981 rear-end was geared better than the 1979 or if there was any other reason to make it beneficial to swap it into my 1979
Re: gear ratio
I believe they are the same if trany was a 5 speed. The auto trans. cars rear end was a bit different.
- divace73
- Your car is a: 1980 Fiat 124 Spider Silver
Re: gear ratio
I believe this to be the case as well, they should be 3.9 if a 5 speednarfire wrote:I believe they are the same if trany was a 5 speed. The auto trans. cars rear end was a bit different.
Cheers David
see my >>You tube channel<<
