By any chance has anyone put together a check list or small manual about installing one of these carbs? I'm a little concerned about how to hook up the electric choke. Also, are their any other problems I am going to run into. Currently, on my 79 I have already swapped out the technocolor intake for an earlier single plane model and a 32adav (or something that has a broken idol screw - check ebay soon if interested or contact me). Anyway, What pitfalls can I prepair myself for? Any help would be appreciated.
34 / 36 DFEV Webber
- tartan18
Re: 34 / 36 DFEV Webber
Installing my DFEV 32/36 was straight forward. No vacuum lines to connect. The electric choke just needs 12v when the ignition is on. Crankcase vent goes to the bottom of the air cleaner. Hooking up the throttle cable is usually the biggest challenge but Mark Allison sells a nifty cable adapter. I just took my accelerator cable to a local motorcycle shop and had them install a small barrel type stop that mated with the carb's linkage.
Jim MacKenzie
1975 Fiat Spider
1975 Fiat Spider
