control arms
- Your car is a: 1980 FI 124 spider
control arms
Will I just finished rebuilding my front suspension new springs,bushings,balljoints,and all steering linkage's question is I know I need to torque the control arms with the vehicle weight on the ground and two passengers in the car how about the lower control arm that mounts to the cross member does this also need to be torqued with the same principles as the control arm bushings or can I just torque this like normal fiat manual says to torque it with the specified weighted so How to you get a torque wrench in there .
Sometimes there is no room for a torque wrench. In this case, I get the fasteners as tight as I can with the car loaded in the neutral postion, then create room for the torque wrench while keeping everything as neutral as possible for the final torqueing (i.e. put jack under control arm so that car is at the normal height, and weight is on the control arm, remove wheel to give you room). When doing so, don't let the item with the rubber bushing move very much between the initial tightening and final torque. In other words, don't jack up the car under the cross member, with the front wheels hanging down, until you have given in the final torque to spec.
Alvon
Alvon
Her are some pics of my front end rebuild.[url]
http://i217.photobucket.com/albums/cc51 ... ure001.jpg
http://i217.photobucket.com/albums/cc51 ... ure002.jpg
http://i217.photobucket.com/albums/cc51 ... ure003.jpg
http://i217.photobucket.com/albums/cc51 ... ure004.jpg
http://i217.photobucket.com/albums/cc51 ... ure005.jpg
Looks very nice! Looks like you have done a very thorough job. You've probably already considered it, I'll mention a few things to be safe: you'll want to wait to torque the bolts at the control arm bushings until you get the rest of the weight of the car sitting on them (engine, etc.), on a level plane. You might also find that you need to repostion some of the tie rod clamps and bolts eventually, so that they won't bang into the exhaust downpipe -- this is something that I ran into, anyways.
Also, you may want to keep the center link ball joints just lightly tightened for now, as you may prefer to remove it when you install the engine and transmission.
Great job!
Alvon
Great job!
Alvon
