timing belt swap pulley question
georgeramos
Post by georgeramos »
Did the timing belt today. aftet all was done I re-checked the timing marks. Everything was spot on except for the aux pulley mark. the manual says it should be pointed at the spring retaining bolt which is about the 2:00 position. It is actually pointing between that bolt and the tensioner fixing bolt (so closer to 1:00 position) Is this OK or do i need to loosen and re-do it?
George
BEEK
Your car is a: 1975 Spider
Re: timing belt swap pulley question
Post by BEEK »
what size engine?
75 spider
son has 78 spider
georgeramos
sorry, 1608
BEEK
Post by BEEK »
you are all good
75 spider
son has 78 spider
georgeramos
Thanks Beek
