Bolt size question
georgeramos
Bolt size question
Post by georgeramos »
My car is at a friends house in Beaverton, we did the front seals, i had the radiator fixed and on Sunday we are planning on putting it all back together including new timing belt, tensioner, water pump etc. Also all new rad hoses, thermostat and a working thermal switch. I also will be installing the correct (1608) timing cover but do not have the bolts that go through the center and lower holes (the ones that keep it in the proper position for the timing marks below) Can anyone tell me what size bolts I need to get for those 2 mounting points? I have the upper bolts only.
George
georgeramos
Re: Bolt size question
got it, its 6mm...
RRoller123
Post by RRoller123 »
If the inner cover is missing (likely) then a spacer is needed too, to keep the cover from being pushed into contact with the crank pulley when you tighten down that bottom bolt.
georgeramos
yes, i bought all the rubber spacers,metal bushings that were needed but forgot to order the bolts.
George
