hey just wondering what this is?
- GDR76SPIDER
to the right of the button?
and also, can i remove the button if i'm installing th 32/36 dfev and getting rid of the vacuum stuff?
- Your car is a: 1976 spider
Re: hey just wondering what this is?
It is a fast idle switch that was part of the smog package. I have a 76 with a 32/36 and have removed it.
I'm sure some other members have a much more thorough explanation...
Don
Don
76 Spider
St. Louis, MO
St. Louis, MO
- GDR76SPIDER
so it's ok to remove both the button and that box type thing to the right of it?donerehart wrote:It is a fast idle switch that was part of the smog package. I have a 76 with a 32/36 and have removed it.
Don
the "box" is the voltage regulator. Unless you're installing an alternator with an internal regulator you'll end up with a dead battery
The box thing to the right is needed... The black button used to have another metal piece called a weber electrovalve underneath it (you can see the mounting spot with the two holes). The black button and what it is mounted to can be removed. I don't think you want to remove the regulator.
76 Spider
St. Louis, MO
St. Louis, MO
- GDR76SPIDER
awesome, thanks guys
