Control module and coil
basman
Post by basman »
Getting ready to install new control module and coil (79 fiat spider). Looks like a simple bolt on project. Anything I should know first???
RRoller123
Re: Control module and coil
Post by RRoller123 »
I am assuming that you mean the small control module that mounts under the coil: Make sure that you use the "thermal grease" that comes in a little squeeze packet with the control module, when you mount it on the heat sink. Without it the CM will overheat and fail quickly.
majicwrench
Post by majicwrench »
Why are you changing them??
basman
Post by basman »
Car dies after it is run and sits or gets hot. Electrical.....tac drops to 0. I was advised that this was the control module and it looks like the original coil so it thought it was time to change it also.
divace73
Post by divace73 »
also check the white wire from the connection point of that module all the way to the dizzy, they get brittle and fray and can cause all sort of issues.
Cheers David
see my >>You tube channel<<
basman
Post by basman »
will do......thanks
majicwrench
Coils almost never fail. Module is a good guess.
Keith
