Wheel bolt size
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Wheel bolt size
Post by dmwhiteoak »
I need to run a tap in one of my wheel bolt holes in the hub but no one seems to carry the tap. I have figured out , or I think, that the bolt size is 12m x 1.25. Is this correct? I have every other side tap but this one and have looked everywhere but a machine shop supply. The vendors also list the bolts at 12m x 1.25. Any thoughts?
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
maytag
Re: Wheel bolt size
Post by maytag »
12x1.25 is correct.
same as Nissan cars and 'some' Subarus. But nowhere near as common as the 12x1.5 found on most import cars.
dmwhiteoak
Re: Wheel bolt size
Thanks, I will continue the search for the tap.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
maytag
Re: Wheel bolt size
Post by maytag »
dmwhiteoak wrote:Thanks, I will continue the search for the tap.
http://www.mcmaster.com/#standard-taps/=j9jzds
can't go wrong here.
dmwhiteoak
Re: Wheel bolt size
Thanks, got it covered. But man, that is the place to go for taps.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
