Engine break in and valve adjustment
Posted: Sat Sep 08, 2012 7:50 am
Hi All,
It's been a procrastinator's dream, but after ten years, my 81 FI is alive, thanks to many in the forum along the way.
I have a couple questions on final adjustments.
1. Engine and head were tore down,(by a knowledgeable friend) new valves, one with a new cut seat angle, seals etc. Head did not need resurfacing. I hear some valve slap, so am about to undergo my first try at the valve adjustment. I read plenty of good threads on the topic, but didn't know if I should put a dozen miles or maybe more miles on it to break it in before measuring the clearance (I will do it cold)? She runs great, except for an occasional miss mainly noticeable at idle. I am thinking. It's electrical so FI connector or distributor as timing cams, crank are dead on and she runs well really good torque. So do I break her in for a bit or just do the valve adjustment measurement now? Also will I spill oil removing the cam cover plates to take my measurements so I can order shims? I am not sure if removing the cover also could break free the cam box bottom gasket?
2. What is the recommendation on when and how to re-torque the head bolts?
3. Engine temp when driving stays at 190, climbs a bit above that then fan kicks in as it should, but the engine compartment gets what seems to me as too hot. All surfaces are uncomfortable to the touch. For example intake manifold cover is hotter than I can tolerate touching, so knowing 150F is too hot to touch, I would assume it's around 135 or more. Is that normal? Air intake is stock, exhaust manifold heat shield I in place. Cooling system is burpped and working fine, top and bottom radiator hoses are hot.
4. There seems to be two types of Bosch FI connectors available, The local parts store has one they say works in place of the box shaped connector, but I am not sure I believe them. The one they want to sell me has more of a curved or fluted side on it. I am thinking I'll just order from the forum suppliers, but was curious if anyone ever used one of curved ones?
Thanks in advance.
Thanks in advance.
