Front & rear shock removal RESOLVED FINALLY
4uall
Post by 4uall »
originally I posted this http://forum.fiatspider.com/f08/viewtop ... 14&t=13646 and I have always been a visual learner so I picked up some Monroe Sensa trac`s and I am ready to take the plunge :shock: Photos are always encouraged and appreciated.
1) is this the top nut that needs to be removed first ?
front shock absorber top nut? by itzebtze, on Flickr
2) how on earth do I get to the drivers side? Looks near impossible to get in there.
3) then remove lower bolt & nut?
Passenger side tire by itzebtze, on Flickr
fiat218
Re: Guidance on front shock removal & replacement
Post by fiat218 »
It a bitch. Lol
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
81SPIDERMATT
Post by 81SPIDERMATT »
it helps if you loosen that top nut while the weight of the car is on the wheels..... jack her up.... loosen the bottom and they fall right out
RRoller123
Post by RRoller123 »
The driver's side top nut is done with a short wrench and by feel. You can get about a 1/8 turn per wrench application. It is a pita for sure.
fiat218
Post by fiat218 »
RRoller123 wrote:The driver's side top nut is done with a short wrench and by feel. You can get about a 1/8 turn per wrench application. It is a pita for sure.
I agree
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
focodave
Your car is a: 1980 Spider 2000 F.I.
Post by focodave »
I agree with 81SPIDERMATT's method.
I just rebuilt my suspension over the past couple of weeks so I have recent experiences.
Reaching the nut is truly a pita.
Looks like you may want to hit it with some PB Blaster.
That will help get things turning.
Otherwise you will need to try to keep the shaft from turning with a much smaller wrench and that is dam-near impossible with such tight space.
You will need a 14mm combination wrench to do the job.
Just be patient --- you will only get a fraction of a turn each time you try to move the wrench. Flip it, and turn again -- repeat, etc, etc.
Good news -- the passenger's side is much easier to get to from underneath the car, reaching up into the area where the nut is located.
1970 MGB GT (my other hobby)
fiat218
Post by fiat218 »
focodave wrote:I agree with 81SPIDERMATT's method.
i used a super big channel lock piers and gripped it on the upper part that turns, i had to go uner the spring and do it, put that on and wired the handle close and twist the wire so it held tight, then as the whole shaft turn it would catch on the spring or where ever , came off then, other wise like u sayd 2 wrenches
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
focodave
Post by focodave »
Fiat 218,
Yep.
That would work -- or small vice-grips.
Any way you cut it, it's a major pita.
It's easy to imagine why Fiat North America failed.
I can see some Chrysler mechanic, long ago, cussing the living daylights out of these cars and just either giving up on them or doing sub-standard work on them in protest of their tight spaces to work, metric sized hardware, etc, etc..
4uall
Re: Guidance on front shock removal & replacement HELP PLEASE
Post by 4uall »
81SPIDERMATT wrote:it helps if you loosen that top nut while the weight of the car is on the wheels..... jack her up.... loosen the bottom and they fall right out
soooooooooooooooooooooooooooooooooooooooooooooo I actually had no issues removing both top nuts and rubber bushings from both driver and passenger sides. Sprayed copious amounts of penetrating oil. Used an extension rod and a flex connect on the ratchet and off they came :wink:
Now when it came to removing the lower bolt :shock: I have the nut off however, I cannot get the bolt off/thru :evil: :cry:
Front shock lower bolt by itzebtze, on Flickr
djape1977
Post by djape1977 »
get a bigger hamer
focodave
Post by focodave »
4Uall,
You need to get the pressure off of the shock by jacking the car up by the crossmember, now that you have the upper nuts completely off the shock(s).
Were you able to rotate the lower shock mounting bolt by putting a wrench on the bolt head and turning?
You may want to try that, along with PB Blaster and, of course, a hammer and something (bar stock?) to drive the thing out all the way.
Focodave
4uall
Post by 4uall »
so mission accomplished :D
picked up a 3lb hammer from HD and quickly came to realize that I now own a 3lb hammer for future use :?
my BFH 3lb Estwing by itzebtze, on Flickr
this is what I discovered :shock:
lower bolt had fused itself to the inner bushing sleeve by itzebtze, on Flickr
Original front shock and lower bolt fused with inner shaft of bushings by itzebtze, on Flickr
sawzall'd the bolt then installed the new ones
New Monroe Sensatrac front shock and bolt by itzebtze, on Flickr
New front shock lower bolt by itzebtze, on Flickr
the passengers side was completed in approx 5min from start to finish because the bolt just came right out smoothly :roll:
thanks for all the help, now on to the rears next weekend..................any advice? :wink:
Wheel
Your car is a: 1982 Fiat Spider
Re: Guidance on front shock removal & replacement RESOVED
Post by Wheel »
Thanks for the helpful thread and photos.
Did you end up cutting the hex bolt head off with a saw?
1982 Fiat Spider
4uall
Post by 4uall »
loving my sawzall right about now :mrgreen:
Wheel
Post by Wheel »
Best tool ever....after the hammer of course!!
By the way, nice hammer. :D
1982 Fiat Spider
