BUT GOD DAM
some people should not work on cars lol
REFERRING to my 79,that i bought from a guy in California
OMG,
\ i was swapping out the sway bar in front,only because the 1" bar he had in front does not fit proper, so anyways back to the original sway bar. so as i was saying .
as i was doing that i removed the front tire on the passenger side, as i was taking the tire off ,it seem to move alot. so i thought wth, anyways as i was looking the bottom ball joint was not even seated up in the socket, here he had uses a pliers or some sharp object on the shiny smooth stem. hell it was so marked up there no wonder why it would not seat. so i took off the control arm,time to replace the whole arm. only because the small bracket that holds the sway bar bracket was busted off and just had bolts thru there,
EVEN I KNOW WHAT RIGHT OR WRONG
i am not a mechanic
i am not a mechanic
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: i am not a mechanic
lol, the stories I could tell about the cars that get dragged in after "repairs" have been attempted. I feel your pain
I believ it, I mean I am not a mechanic , just a brick mason lolSo Cal Mark wrote:lol, the stories I could tell about the cars that get dragged in after "repairs" have been attempted. I feel your pain
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Your car is a: 1982 Spider
I'm a psychologist and can only tell when my car "feels" bad.
Steve
1982 Red Spider 2000
1919 Old Town Sailing Canoe
thats good then2ndwind wrote:I'm a psychologist and can only tell when my car "feels" bad.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
LMFAO!
This is why I triple check and always ask this forum before I tackle anything
Jim, is this the same car you were stretching out on the freeway last month? I have learned the hard way to check used cars well beforehand . It's good you didn't learn of the ball joint the hard way.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
Had my car into G&S for a clutch replacement and the super mechanic found the PO had an upper ball joint in the lower arm, or a lower in the upper I don't remember....but it sounded wrong and he fixed it. Amused and pleased he found it.....I do know ball joints are not in close proximity to the clutch! Love that man.
yes it that same car , running at 100 on the free way. u are so right ,check the car over good before doing a test rundmwhiteoak wrote:Jim, is this the same car you were stretching out on the freeway last month? I have learned the hard way to check used cars well beforehand . It's good you didn't learn of the ball joint the hard way.
lower control arm arrived today
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
