Page 1 of 1
Fuel Line Connections From Tank
Posted: Sat Aug 25, 2012 9:24 pm
by ylbill
Wasn't sure where to post this. I was hoping someone had a picture of where the fuel lines connect from the tank. I have a hole right about where the back seat is with two lines coming out of it. Somehow I'm thinking that a hole under the car is not a good thing. Pictures would be great. Thanks
Re: Fuel Line Connections From Tank
Posted: Sat Aug 25, 2012 9:31 pm
by blurple124
Hey, could be worse....
If you can see around the corrosion and leaky fuel, the lower line is the return and the upper line is (was) the supply line.
The connections on the tank itself are easier, since they are different sizes (smaller one is return). If that isn't enough, when you are looking at the front, the return is on the right side.
I just finished replacing my fuel lines about 15 minutes ago, so I can attest to this.
Posted: Sat Aug 25, 2012 10:09 pm
by 4uall
