Can anyone tell me if the front and rear springs on the 124 spider are square on both ends, Tangential on both ends or a mix?
Here is a link to eaton springs, if you need an explanation of the terminology.
http://www.eatonsprings.com/cuttingcoilsprings.html
info request
- jpaulus53
- Your car is a: 1977 fiat spider
- blurple124
Re: info request
They are square.
Left is '78, Right is '69. I would imagine that all other years follow suit.
Charlie
1978 Fiat 124 Spider 1800 - Antonia
1997 Jeep Wrangler TJ Sport
- jpaulus53
Re: info request
Hmmm. they look square on the bottom and tangential on top
- azruss
Re: info request
all my factory springs are squared off on the end.
- jpaulus53
Re: info request
Ok thanks
- blurple124
Re: info request
Most likely an illusion from the photo angle.jpaulus53 wrote:Hmmm. they look square on the bottom and tangential on top
Charlie
- jpaulus53
Re: info request
OK and thanks to all. Now one last set of questions.
Can anyone tell me the outside diameter of the spring?
This is critical for where the spring sits in the thrust ring.
And the inside diameter, critical for shock clearance.
thanks
thanks
