springs
- Your car is a: 1985 Spider
Re: springs
I installed these springs about four months ago and could not be happier.akawes wrote:has anyone put coil overs into these cars successfully? Or has anyone used autoricambi's lowering springs.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
Re: springs
right on. How much do those springs lower the car and what kind of shocks are you using?
Re: springs
KYB and it lowered it about 1 inch.akawes wrote:right on. How much do those springs lower the car and what kind of shocks are you using?
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
Re: springs
Keep in mind that these springs will lower a later car and raise an earlier car.
- blurple124
Re: springs
I have a question about that actually. I have a set of springs from a '69 that I was going to put on my '78, but opted not to because they look to be exactly the same length. Are they? Is it a difference in stiffness?
('69 on left)
('69 on left)
Charlie
1978 Fiat 124 Spider 1800 - Antonia
1997 Jeep Wrangler TJ Sport
- divace73
- Your car is a: 1980 Fiat 124 Spider Silver
Re: springs
the one on the left looks thicker?? I woudl imagine the thicker the stiffer???? (maybe depend on material type, don't know if it's all the same?)
Cheers David
see my >>You tube channel<<
- blurple124
Re: springs
Nope, I just took the calipers out and checked them now. They are virtually identical.
13 mm in the front and about 12 in the back.
Charlie
- blurple124
Re: springs
So why is it that (supposedly) I can put these springs from a '69 on my car and it will make it lower?
What is the difference between these springs?
Charlie
- divace73
Re: springs
if that is the case then the material the older spring is different, may fatigued a little??blurple124 wrote:So why is it that (supposedly) I can put these springs from a '69 on my car and it will make it lower?
Cheers David
Re: springs
did u get those springs from me?blurple124 wrote:So why is it that (supposedly) I can put these springs from a '69 on my car and it will make it lower?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: springs
id like to add to this, because i had sold a set of springs to some one from my 69/ and just before that i was getting my 80 suspension redone, and i measured the springs on my 80, i really can't recall what they where but the front ones on my 80 was different in the front and back,for height,. i measured the 69 springs just after i took them off and sent them, and if i recall there where so close in height, i just cant recall what the numbers where. don't know how that would lower anythi g but as some one said possible tired spring? i dunnoblurple124 wrote:I have a question about that actually. I have a set of springs from a '69 that I was going to put on my '78, but opted not to because they look to be exactly the same length. Are they? Is it a difference in stiffness?
('69 on left)
on your spring photo. it looks like the left ( 69 u said ) is shorter then the black one.FROM the photo
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
