Unleaded gas ?
pluto
Unleaded gas ?
Post by pluto »
Can I run a 1970 Fiat Spider on unleaded gas or do I have to add lead substitute ?
spidernut
Re: Unleaded gas ?
Post by spidernut »
Lead was used to boost the octane. You can run unleaded, but may have to go to a higher grade to avoid pinging.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
vespistiSF
Re: Unleaded gas ?
Post by vespistiSF »
Yes you can. Some people recommend using the lead substitute to avoid premature wear of valve seats. All my old cars run on premium unleaded. I don't add lead substitute on any of them and haven't had any problems.
pluto
Re: Unleaded gas ?
Post by pluto »
Thanks to all.
GeorgeT
Re: Unleaded gas ?
Post by GeorgeT »
Your bigger problem is ethanol in most of the gasoline sold today. The fuel lines and carburator seals in older cars were not designed to ba stable with alcohol and deteriorate much faster. Fermented and distilled corn should be made to drink, not burned in cars.
majicwrench
Re: Unleaded gas ?
Post by majicwrench »
The lead also helps with valve seat longevity.
Fiat, with their alum head, has nice, hard valve seats in em.
I have a 64 Chev PU, with cast iron valve seats, and without the lead, it beat the valve seats waaaayyyy down. I kept adding shims to the valve springs so I could drive it. Finally replaced the head.
Anything that you really love, without hardened valve seats, should really have some help if it is driven much.
Keith
maytag
Re: Unleaded gas ?
Post by maytag »
majicwrench wrote:The lead also helps with valve seat longevity.
Keith
+1
If you don't plan on getting into the motor, you should plan on using a lead additive.
