Removing the F emblem on the side panel
Does anyone know how without taking off the fender do you remove the F bertone emblem on the side of the spider just in front of the door?
Re: Removing the F emblem on the side panel
Front of the door? any chance of a picture? the emblem behind the door is accessed by removing the plastic liner inside the car.
Reminds me of Monty Python's Life of Brian
Jim
Jim
Oh don't get me started..Jimb wrote:Monty Python's
If you want to replace it look no further than mark allison at allison automotive...
I assume spidermark on ebay is the same business...
I ordered 4 of these from him, they are very nice, heavy, solid thick. The colors pop well enough...
Very high quality...worth the price
And its a pininfarina f by the way, not bertone
YES .......all good............but how do you remove them?OffThaHorse wrote:If you want to replace it look no further than mark allison at allison automotive...
If you remove the inside plastic quarter panel behind each seat, there are access holes to get at the back of the emblem. It is somewhat of a pita working through the access holes. Some of the emblems just push in to plastic seating bits, this is the way mine was, so I was able to just carefully pop them off and press in the new ones from the outside of the car.
thanx for thatRRoller123 wrote:If you remove the inside plastic quarter panel behind each seat, there are access holes to get at the back of the emblem. It is somewhat of a pita working through the access holes. Some of the emblems just push in to plastic seating bits, this is the way mine was, so I was able to just carefully pop them off and press in the new ones from the outside of the car.
- courtenay
I'm a lumberjack and I'm OK...
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
...Unless you have one of
<<<<<<< These (see avatar) where earlier cars had the Pinin "f".
