anY HINTS ON HOW TO REMOVE THE CONSOLE FROM MY 84 SPIDER. hAVE ALL FASTENERS THAT I CAN SEE OUT.
DOES THE FACE OF RADIO CONSOLE NEED TO COME OFF IF SO HOW.
REMOVING THE CONSOLE FROM 84 SPIDER
Re: REMOVING THE CONSOLE FROM 84 SPIDER
lower. or upper?larrybarone wrote:anY HINTS ON HOW TO REMOVE THE CONSOLE FROM MY 84 SPIDER. hAVE ALL FASTENERS THAT I CAN SEE OUT.
upper i will say they are all the same, 4 screws should be holding the upper down on the lower
the upper should come out, might be pushed up at the top so u would have to lift up at your dash a tad, or unscrew the bottom one and maybe push down on the lower console to get the upper out
lower
all i have seen was couple screws in the bottom front and under the rear ashtray, could be a screw holding the back down
that all i know
hope it helps
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
