How are they removed? Is it typically push-in, adhesive, or nuts on an '82? I have two replacements coming tomorrow. I haven't looked at the hood yet, but the backside of the trunk emblem is covered with sheet metal.
Brandon
Removing hood and trunk emblem on '82
- bran100
- Your car is a: 1982 Spider
Brandon
Lots of pics: https://www.adoberevel.com/shares/cc771 ... 197cf3ce11
Re: Removing hood and trunk emblem on '82
There is a black plastic round plug on the underside of the hood below the emblem. Pull that and you will see the studs and two tiny nuts (5-6mm) un-do those and the emblem comes off. DON"T PRY.
The trunk is a bit different in that there are two small holes in the sheet metal that you should be able to access the studs.
- divace73
- Your car is a: 1980 Fiat 124 Spider Silver
I have an 80 and both of mine were push in???
Cheers David
see my >>You tube channel<<
- bran100
I found the black plastic cover on the backside of the hood emblem, and on the '82, it seems the emblems are push in. The first pic shows the hood emblem with one of the plastic clips on it. I ended up cutting through the plastic with a knife, and using a needle nose to peel it apart.
The trunk emblem looks a lot harder as there is painted sheet metal over the clips. See the second picture. This is after I bent the sheet metal out of the way. I'll work on getting that one off tomorrow.
thanks all.
thanks all.
Brandon
- giuliot60
- Your car is a: 81 Fiat Turbo removed Spider
How did you resolve this? I have an '81 and I'm planning on removing them soon to install a vinyl center stripe. Like my Photoshopped avatar
Giulio/Charlotte
- 81SPIDERMATT
my 81 has the nuts.... but not sure if they are original..got to them as narfire saidgiuliot60 wrote:How did you resolve this? I have an '81 and I'm planning on removing them soon to install a vinyl center stripe. Like my Photoshopped avatar
