After shearing one bolt, which it sounds like I will have to drill and tap, I have the sway bar off.
Now I cannot get the bushing brackets to come apart! It looks like there is some kind of collar in the bolt hold, but I don't know how to deal with this.
Any thoughts?
Front Anti-Sway Bar Brackets are Stuck!
- blurple124
Charlie
1978 Fiat 124 Spider 1800 - Antonia
1997 Jeep Wrangler TJ Sport
Re: Front Anti-Sway Bar Brackets are Stuck!
Simply use a drill bit just big enough to drill the collar out so they come apart.
When you put them back on just ensure you tighten them up evenly and with load on the wheels for final torque.
I have same problem in terms of stud shearing.blurple124 wrote:After shearing one bolt, which it sounds like I will have to drill and tap, I have the sway bar off.
Any thoughts?
I'm wondering if tapping and using a bolt works or if it is better to get a stud welded in.
Geoff
- blurple124
I did both, as a batter of fact. Just the other day we picked up an M8-1.25mm tap with matching stud and nuts.
Ground flat, drilled and tapped the sheared stud, then threaded the new one in. It might have been strong enough, but just for extra measure I tacked it in there with the welder. Better than new now!
Charlie
from my experience so far don't even attempt to work on suspension of a fiat if you don't have spare bolts and welder handy.
Thanks for photos. That looks really good.blurple124 wrote:I did both, as a batter of fact. Just the other day we picked up an M8-1.25mm tap with matching stud and nuts.
Now the only item i need to figure out is a source for the studs.
Bolts are easy to find. Studs less so. I guess worse comes to worse i can just cut a bolt.
Again thanks for info.
Geoff
Geoff,
Maryland Metrics and in your backyard, McMaster Carr http://www.mcmaster.com/# has metric studs
http://www.mcmaster.com/#metric-studs/=j0u5q2
Ralph
Ralph
