Addco sway bars
Addco sway bars
I just got set up as an Addco Sway Bar dealer. My initial stock of performance sway bars will arrive in about two weeks.
RoyBatty
Re: Addco sway bars
Post by RoyBatty »
So how much for a rear bar?
Re: Addco sway bars
it depends on the year of your car. There are two different rear bars
RoyBatty
Re: Addco sway bars
Post by RoyBatty »
OK then,
So how much for a rear bar on a '75 Spider?
I don't yet see them listed on your web pages.
fiat218
Re: Addco sway bars
Post by fiat218 »
So Cal Mark wrote:I just got set up as an Addco Sway Bar dealer. My initial stock of performance sway bars will arrive in about two weeks.
How do u put them on,when they really don't fit, well it seems that this 79 I picked up had a stck of washers holing in place, I will assume u know how it goes on, or how i can fix this so it on the right way, let me know thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
Kevin1
Re: Addco sway bars
Post by Kevin1 »
"this 79 I picked up had a stck of washers holing in place"
An Addco bar fit nicely on our '80. Whoever installed yours must have been missing the hardware that comes with the bar. Or adapted a bar for a different car. Maybe Addco will sell just the hardware kit and you can set it up correctly. The difference in handling is like night and day.
Tobi
Re: Addco sway bars
Post by Tobi »
My Addco bar did not work at all so I called Addco and they send me different hardware. With the new hardware I made it work by fabricating my own shims and washers and it took me several hours.
That was fife years ago and one would think they took care of the problem, did they?
fiat218
Re: Addco sway bars
Post by fiat218 »
Tobi wrote:My Addco bar did not work at all so I called Addco and they send me different hardware. With the new hardware I made it work by fabricating my own shims and washers and it took me several hours.
Well I am not sure if mine is right, but I shaved off a 1/4 inche of rubber on one corner and stuck it on, we see what happens
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
