Brake Part Info?
opus10583
Your car is a: 1978 CS1
Brake Part Info?
Post by opus10583 »
Hi,
I'd like to have as much in hand as possible for my disk and pads replacement project:
What size are the front and rear caliper support bracket mounting bolts, more specifically what size are the lock washers?
What size are the caliper locking block cotter pins?
Thanks,
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
opus10583
Front Caliper Mounting Block Bolt Spec?
Post by opus10583 »
Hi,
I'm MISSING a mounting block bolt! Can't take the other out to match at this time...
Can anyone please tell me what bolt spec is?
Thanks,
Mark
mgbgtn
Re: Brake Part Info?
Post by mgbgtn »
The bolt is 10 mm dia., 17mm long with a thread pitch of 1.25. The hole dia. for the pin is .125". Hope this is what you need.
opus10583
Post by opus10583 »
mgbgtn wrote:The bolt is 10 mm dia., 17mm long with a thread pitch of 1.25. The hole dia. for the pin is .125". Hope this is what you need.
THANK YOU!
Mark
opus10583
Post by opus10583 »
Hmmm... Midwest-Bayless has one at ~25mm
http://www.midwest-bayless.com/storefro ... =256239618
...and I've empirically determined 20mm is way too long.
Any chance there were spacers of some sort on the '78s?
Thanks,
Mark
