repacking the front wheel bearings
In another post I talked about adjusting the front wheel bearings. A friend told me I should have repacked them first but the shop manual mentioned only adjusting them and then packing the cap. So who's right?
Re: repacking the front wheel bearings
I believe you should allways pack the bearings with grease prior to instalation. I know people who also cram as much grease into the hub and cap that is possible. I do not and have had no trouble, although repacking and checking wheel bearings are part of the maintenance that I try to do on a yearly basis on all my vehicles.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
I wish there was more vids like this one on our car!
Cram it indmwhiteoak wrote:I believe you should allways pack the bearings with grease prior to instalation. I know people who also cram as much grease into the hub and cap that is possible. I do not and have had no trouble, although repacking and checking wheel bearings are part of the maintenance that I try to do on a yearly basis on all my vehicles.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- giuliot60
- Your car is a: 81 Fiat Turbo removed Spider
That is a very good video Jay.
Pack the grease in! Also do the bearings if you can.
Giulio/Charlotte
- hayesbd
- Your car is a: 1973 Spider
The proper way to set the wheel bearing endplay is as follows:
1. Tighten the nut to around 15 ft-lbs while spinning the hub 4 or 5 turns in each direction to seat the bearing rollers.
2. Back off the nut and re-tighten to 5 ft-lbs.
3. Back off 30 degrees and stake the nut into the the spindle groove.
These steps are a paraphrase of the shop manual and are obviously designed to set a small amount of endplay on the bearings. Fiat does not recommend setting the bearings up with any preload, even though many mechanics routinely do this. The reason for this is that it is impossible to reliably generate a predictable, consistent preload and it is breathtakingly easy to put it together with too much preload which will destroy the bearings very quickly. I cannot tell you how many times I have seen improperly adjusted wheel bearings with both passenger cars (my hobby) and heavy trucks (my profession as engineer).
Hope this helps.
Brian
Hope this helps.
Brian
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
ok this make sense i dont have a repair man. this is the way i do it but was not sure if fiat has a pre load or not
thanks alot
thanks alot
