Adjusting wheel bearings
Italchic
Post by Italchic »
My shop manual describes adjusting the front wheel bearings by using a torque wrench to retighten the hub nut and then using a flat chisel to "crimp" the nut in it's new position. How does one go about crimping the nut??
thefeline
Re: Adjusting wheel bearings
Post by thefeline »
The spindle will have a slot cut into it and the bolt will have a thinner shank on the top of it. Once the nut is tightened down correctly you just dent that shank into the grove with a chisel/punch so it wont back off as easy.
Italchic
Post by Italchic »
Thanks, I guess I'll find out what all that means when I get into it.
Italchic
Post by Italchic »
OK then, I just finished adjusting the front wheel bearings, all went according to the shop manual's instructions and the play is gone.
thefeline
Post by thefeline »
Good work!
Italchic
Post by Italchic »
Thanks and thanks. Also tightened up the alt. belt. Next on the list is to install a mech oil press gauge to get a more accurate reading. Just waiting for the metric adapter to arrive.
4uall
Post by 4uall »
I realize you are done however, here is a great video
http://www.youtube.com/watch?v=3LC9MxUCvI8
giuliot60
Your car is a: 81 Fiat Turbo removed Spider
Post by giuliot60 »
I've also heard that you can hand tighten, the give it another 1/4 turn. Is that true?
Giulio/Charlotte
wikkid
Post by wikkid »
Did you just check, re-pack, and re-tighten, as opposed to changing the bearings out with new? How many miles on the car? Edit: whoops - just saw your other post on this.
