I am restoring a rear floor pan on the drivers side for my spider
And can't seem to trace the fuel lines from the engine compartment to the gas tank
Could some one on this forum please help out
Any idea if the fuel lines are near this area that I will soon be welding the rear drivers floor pan in
Thanks for all the help
Ron
Help with 1971 spider 124 fuel line layout
Re: Help with 1971 spider 124 fuel line layout
On a '71, I believe you'll have three steel lines running along the underside of the car, loosely following the edge of the transmission tunnel.
Easy way to check, look above the axle on the driver's side, you'll see the three flexible fuel hoses that exit the trunk. Just follow those...
Excellent help , thanks for the quick response ,same day service huh !
I have located the fuel lines and I'm good to go
Great forum
Ron
Great forum
Ron
