Brake Parts for 1978 Spider
Posted: Fri Apr 20, 2012 4:35 pm
I've cross-threaded one of the brake-line ends into the "splitter" fitting that's located near the rear axle (don't know what this part is called, but the brakeline from the compensator connects to this fitting and sends brake fluid to each of the 2 rear break calipers). I need to either replace this fitting, or re-tap the female threads that were damaged. Anyone know what this part is called and where to get it? Or, what size tap is needed to cleanup the threads?
